VEYE 2Mega STATVIS Camera Module Technical Details
Technical Details
SENSOR
Sensor SONY IMX290LQR-C STARVIS
Pixels 2.13M pixels
Image Size Diagonal 6.46 mm (Type 1/2.8)
Unit Cell Size 2.9um (H)*2.9um(V)
ISP
Frame Rate 1080p@25 / 1080p@30fps
Exposure Auto or Manual
White Balance Auto or Manual
Shutter 1/25(1/30)s to 1/50,000s
Slow Shutter Support
Denoising 2D/3D noise reduction
Image Setting Brightness, Contrast, Sharpness, Saturation,Flip, Mirror
Image Enhancement BLC, DOL-WDR, Defog
Day/Night Switch Manual or IR-CUT filter with external trigger
Lens & IR-CUT
Lens Support M12*0.5 or M16*0.5 depend on lens mount
Lens Mount with IR-CUT MTV12 or MTV16
Mounting Hole 2 screw holes with diameter of 2.1mm,
Centre distance of 20mm
Interface
PCB Connector BTB050040-F1D
Communication Interface IIC
Video Data Interface LVDS:3Lane, Bandwidth 1.5582Gbps or
MIPI:2Lane, CSI2 YUV422-8bit Data Type, Bandwidth 1.188Gbps
IR-CUT Control IR-CUT motor control, 3.3VDC level
External Trigger Ambient light synchronization, 3.3VDC level
General
Operating Conditions -10℃-50℃, Humidity 95% or less, non-condensing
Power Supply 3.3VDC
Power Consumption 3.3VDC,1.2W
Dimension 38mm*38mm*8mm(not include lens and IR-CUT)
Leave a Reply
Your email address will not be published.
